Screenmate One, android sur votre écran
davcbr
Voiture : Model 3 perf
Re: Teslogic Screenmate
Message par davcbr »
Merci de l'info, apparemment pas de différence sur le modèle à commander ;=)
Calico
Message par Calico »
Je n’ai pas été réactif pour vous partager l’info mais c’est dispo depuis début de semaine dernière.
:new: Nouvelle mise à jour disponible ! :new:
Screenmate OS 1.0.8 (PRODUCTION)
Build date: 28 mai 2026 15:16
Fingerprint: qti/qssi/qssi:14/UKQ1.250403.001/tdrk05281516:user/release-keys
1.0.8 hotfix.
•**IMPORTANT FIX:** Fixed storage issues that could cause the disk to fill up and lead to slow system boot times. After installing the update, the system will automatically free the incorrectly occupied space. No user action is required.
• Added the Screenmate AirPlay app
• Reworked the system GPS service so all apps can correctly interpret the signal (requires a CAN MCU firmware update, which should install automatically)
• Fixed lock screen, PIN code, and desktop wallpaper settings
• Significantly improved video stream stability in Tesla Interface (requires a Video MCU firmware update)
• Improved wireless CarPlay connection stability, added steering wheel media controls, and stabilized navigation voice prompts with proper audio ducking
• Updated the CarPlay app Ul to show the app version and Wi-Fi hotspot details, including band and channel
• Synchronized the system bar temperature settings with the Screenmate app
• Fixed SMS reception and USSD code sending
• Optimized the cooling fan curve
• Added an app auto-start delay setting to improve stability
• Improved Bluetooth automation speed and reliability, with added RHD support in Tesla Interface
• Added quick shortcuts in Screenmate settings to system settings, data reset, and PIN/ screen lock settings
• Added app switching from the right .scroll, with configurable mode, app source, and hold delay
• Added Bluetooth settings for Tesla access to contacts and messages, and improved tips for connecting Screenmate One Audio (re-pairing with the car is recommended)
• Added a setting to restore the screen source after the car is unlocked
• Added a contact field for bug reports
Model 3 Long Range AWD 2023 - S3XY Knob&Buttons&Strip&Dash 😍 Screenmate aussi
y
youtani
Message par youtani »
Yes j'avais pris la photo pour faire de même mais j'ai oublié :smile:
La localisation marche sans problème maintenant, donc Google Maps / Waze son utilisables.
Toujours très content du système, bien réactif, simple d'utilisation.
davcbr
Bon voilà j’ai reçut le mien, les mise à jours c’est automatique ? je vais l’installer j’espère cette semaine
Calico
Non, pour les mises à jour, il y a une application Updater dans l’appareil.
Bien penser à flasher le video MCU et le CAN MCU après avoir fait la mise à jour de Screenmate
davcbr
j'ai rien compris ;=)
tu as un lien par hasard?
Calico
Haha :) Je ne crois pas que ce soient les pros de la doc. C’était une vraie nébuleuse quand j’ai déballé le produit, trop peu d’infos.
À l’usage c’est l’OS Android donc si tu as une tablette tu seras très familier avec l’interface.
Y’a des apps pré installées dont une qui s’appelle Updater et dedans t’as ce qu’il faut pour gérer la mise à jour du Screenmate au niveau du système, et également des boutons pour flasher des éléments qui se chargent de l’interaction avec le système Tesla, notamment l’écran tactile, et la communication avec le bus CAN qui est le « réseau » du véhicule et qui permet au Screenmate d’interagir avec lui.
Ne cherche pas à te prendre la tête au début à te balader dans les menus, fais la mise à jour en premier car les premières versions délivrées sont très loin derrière en terme d’ergonomie par rapport aux MAJ récentes.
davcbr
Ah super merci de l'info sa m'aide
Re: Screenmate One, android sur votre écran
Notre partenariat avec Screenmate est renouvelé pour 2026 sur l'ensemble des produits de leur gamme. Parfait si vous voulez acheter le boîtier Screenmate One.
:Fleche: Lien : Site Screenmate
:check: Code de réduction de 10% : BLOGTESLAFR
luis60
Voiture : Tesla 24 x and 22 y
Message par luis60 »
Actuellement, j'ai mis à jour jusqu'à la version 1.0.8, mais les données de localisation GPS ne sont pas précises. Il semble que les données de localisation lues depuis le câble CAN du système infotainment Tesla ne soient pas parfaites. Cependant, il est possible de simuler la localisation en ajoutant un module GPS avec interface USB, ce qui améliore nettement le nombre de satellites et la vitesse de localisation. J'espère que cela s'améliorera dans les futures mises à jour.
y
youtani
Tu es bien sûr que les données de localisation viennent du système Tesla et pas de ton téléphone en partage de connexion ?
Calico
Dispo depuis aujourd’hui.
Soyez patient après le redémarrage, l’updater flashe pas mal d’éléments (j’avais régulièrement un message Android sous forme de popup « Updater ne répond pas » avec comme choix « Fermer l’application ou Attendre). En fait vous verrez que y’a une notif en attente de l’app Updater qui vous invite à redémarrer le Screenmate
Screenmate OS 1.0.10 (PRODUCTION)
Build date: 26 juin 2026 10:05
Fingerprint: qti/qssi/qssi:14/UKQ1.250403.001/tdrk06261005:user/release-keys
1.0.10 hotfix2:
• Updated the system APN database. Mobile network settings should now be detected automatically for most carriers. If automatic setup still does not work, please request custom APN settings from your carrier
• Fully redesigned the Screenmate sidebar: added layout customization and support for adding new action and shortcut buttons
• Added many new sidebar controls for seats, climate, lights, locks, wipers, regen, drive modes, and more
• Added a dashboard overlay in Tesla Interface with key driving info, including indicators, temperatures, clock, FSD max speed, and blind-spot status.
• Added Tesla Interface settings to the Screenmate Settings app, including dashboard visibility, dashboard auto-hide, reverse camera overlay, temperature units, and fullscreen behavior
• Updated GPS handling for China-market vehicles, both inside and outside China. Coordinates should no longer be shifted in China, and should no longer stay locked inside China.
• Added Updater settings, including automatic installation of partial updates, automatic component installation, and other update options
• Fixed a Home Screen boot loop issue
• Improved CarPlay call handling, connection recovery, and music playback
• Improved right-hand-drive support and image positioning
luis60
de mieux en mieux
Calico
Screenmate OS 1.0.11 (PRODUCTION)
Build date: 9 juil. 2026 12:43
Fingerprint: qti/qssi/qssi:14/UKQ1.250403.001/tdrk07091243 user/release-keys
1.0.11:
• Fixed GPS data compatibility with Tesla update 2026.20.6.1+ (requires a CAN MCU update, which should install automatically)
• Added a new way to play Screenmate audio through the Tesla browser, configurable in Sound settings
• Added passenger climate control and the ability to turn climate off with a long tap on the temperature
• Updated the Home Screen icon layout with a more compact arrangement
• Increased hitboxes for bottom bar buttons and Home Screen icons
• Synchronized settings across all system apps
• Fixed disappearing icons (showing as gray squares) in split-screen templates
• Fixed incorrect system audio volume steps when connected over Bluetooth
Calico
J’ai testé l’audio via le navigateur Tesla, bluffant !
Le son est propre, le délai paramétrable, c’est royal
y
youtani
Ca sert à quoi d'avoir l'audio via le browser plutôt que via le bluetooth ? Pour garder la connexion bluetooth du tel en permanence ?
Mais bon c'est un peu relou d'avoir à lancer le browser pour le son, non ?
Mais le Teslamate peut faire du partage et connexion wifi (pour transmettre le son) ET se connecter en wifi sur un tel ?
Calico
Screenmate OS 1.0.12 (PRODUCTION)
Build date: 3 août 2026 14:26
Fingerprint: qti/qssi/qssi:14/UKQ1.250403.001/tdrk08031426:user/release-keys
1.0.12:
• Fixed voice input when connected to Tesla Bluetooth
• Added a Tesla turn-signal camera overlay with an optional 1.5x larger view
• Added automatic Tesla Bluetooth connection when switching to Screenmate, including automatic retry and manual controls
• Added a button to connect Tesla's priority Bluetooth device
• Web Audio now plays navigation prompts and voice assistant audio through the Tesla browser
• Fixed battery preheating on Tesla firmware 2026.20.6.1 and later
• Updated the cellular carrier APN database. If mobile connection issues persist, please submit a bug report
• Fixed system time synchronization
• Fixed search in system settings
• Fixed Home Screen widgets that require configuration
• Adjusted the housing temperature sensor threshold that could incorrectly cancel system tasks
• The Dashboard now remembers its position and automatically hides over system screens
• Improved CarPlay startup, reconnection, iPhone discovery, video stream stability, and compatibility across 2.4 GHz and 5 GHz Wi-Fi environments
• Added automatic Bluetooth pairing confirmation for iPhones in CarPlay, configurable in Settings
• Improved Siri, call, and navigation audio in CarPlay, with fewer stutters, gaps, and cut-offs
• Added YouTube link compatibility in Screenmate AirPlay
• Added an option to take screenshots and share them directly from the Tesla Interface app
• Adjusted the Autopilot speed-limit overlay position in the Tesla Interface app for FSD 14 Lite compatibility
• BugReport now saves contact details and supports voice input
Ils mettent le paquet sur les développements, c'est bien !
Calico
Je sais pas pour les autres mais sur la version 1.011, l’interface Tesla reprise dans Screenmate avait des petits ralentissements et une légère latence, pas terrible pour la partie stationnement par exemple, alors que cela fonctionnait plutôt bien avant.
Je n’ai pas encore eu l’occasion de réessayer depuis pour voir si cela a été corrigé.
luis60
Mise à jour effectuée, il semble y avoir un problème avec l'appel de la caméra, qui affiche toujours celle de gauche.
