Page 1 sur 11
Mise à jour 2023.6
Publié : 04 mars 2023 21:15
par philhor
La prochaine mise à jour arrive :bounce:
Steering Wheel Heat
Automatically heat the steering wheel based on the climate control set temperature. To access the heating controls, tap the temperature settings.
New Language Support
You can now select Icelandic as your touchscreen language. To update your language settings, tap Controls > Display and select your preferred language from the 'Touchscreen Language' drop-down menu.
Dog Mode
View the interior camera from the mobile app while using Dog Mode or Sentry Mode. To enable Live Camera, tap Controls > Safety > View Live Camera via Mobile App.
Note: This feature requires Mobile App version 4.15.0+ and Premium Connectivity.
Sentry Mode Live Camera Access
View your car's surroundings from the Tesla app when parked to confirm the safety of your environment before returning to your car. Live Camera is end-to-end encrypted and cannot be accessed by Tesla. To enable or disable, tap Controls > Safety > 'View Live Camera via Mobile App' from the touchscreen display.
Note: This feature requires Premium Connectivity.
Trip Planner
Trip Planner will add stops at Superchargers if charging is needed to reach your destination.
Zoom Meetings
Make video calls with Zoom using the interior cabin camera. If you have a Zoom meeting in your Calendar, tap the link to automatically start or join your meeting. Participant video and screen sharing are only visible while parked and will switch to audio-only if you drive. To access Zoom, tap Application Launcher > Zoom.
Apple Music
Stream over 100 million songs and 30,000 playlists ad-free. Listen to your entire library, discover new music, and tune into live radio stations. To access Apple Music, tap the Apple Music icon in the Application Launcher, scan the QR code with your mobile device, and login with your Apple ID.
Note: A Premium Connectivity subscription is required to stream Apple Music over a cellular connection.
Improvements to Apple Music
With this update, Tesla has made improvements to Apple Music. When playing a playlist or album, Apple Music will now display upcoming songs in the 'Up Next' section like other music services.
Tesla appears to also have made various improvements to improve the playback and speed when streaming Apple Music. Users are reporting a smoother and faster experience when streaming music.
Welcome Screen
The new Model S and Model X will now display a visualization of the vehicle on the center screen. Similarly to the Model 3 and Model Y, this gives owners easy access to open the frunk and trunk, as well as lock or unlock the vehicle.
This prevents owners from having to go to Controls every time they need to open the frunk/trunk from inside the vehicle.
The visualization goes away once you tap any other area of the screen.
Re: Mise à jour 2023.6
Publié : 04 mars 2023 23:53
par leonkennedy
En effet!
Cars on update
86
Percent of cars
1%
Pending
44
Installs Today
17
Yesteesay
73
Ça commence tout doucement :clin:
Publié : 05 mars 2023 00:09
par Olival68
Elle arrive mais elle n’apporte rien du tout. 80 % ne concerne pas la France et les 20 % restants sont, à mon sens, des corrections de fonctionnalités existantes.
Publié : 05 mars 2023 06:53
par Franch77
Bonjour En Français:
Chaleur au volant
Chauffer automatiquement le volant en fonction de la température réglée par la climatisation. Pour accéder aux commandes de chauffage, appuyez sur les paramètres de température.
Prise en charge des nouvelles langues
Vous pouvez maintenant sélectionner l'Islandanais comme langue de l'écran tactile. Pour mettre à jour vos paramètres de langue, appuyez sur Contrôles > Affichage et sélectionnez votre langue préférée dans le menu déroulant « Langue de l'écran tactile ».
Mode chien
Visualisez la caméra intérieure à partir de l'application mobile tout en utilisant le mode Chien ou le mode Sentinel. Pour activer la caméra en direct, appuyez sur Contrôles > Sécurité > Voir la caméra en direct via l'application mobile.
Remarque : cette fonctionnalité nécessite la version 4.15.0+ de l'application mobile et une connectivité Premium.
Accès à la caméra en direct en mode Sentry
Consultez l'environnement de votre voiture à partir de l'application Tesla lorsqu'elle est garée pour confirmer la sécurité de votre environnement avant de retourner dans votre voiture. La caméra en direct est cryptée de bout en bout et ne peut pas être consultée par Tesla. Pour activer ou désactiver, appuyez sur Contrôles > Sécurité > 'Afficher la caméra en direct via l'application mobile' à partir de l'écran tactile.
Remarque : cette fonctionnalité nécessite une connectivité Premium.
Planificateur de voyage
Trip Planner ajoutera des arrêts aux Superchargeurs si une recharge est nécessaire pour atteindre votre destination.
Réunions Zoom
Faites des appels vidéo avec Zoom à l'aide de la caméra intérieure de la cabine. Si vous avez une réunion Zoom dans votre calendrier, appuyez sur le lien pour démarrer ou rejoindre automatiquement votre réunion. Le partage de la vidéo et de l'écran des participants n'est visible que lorsqu'il est stationné et passera à l'audio uniquement si vous conduisez. Pour accéder à Zoom, appuyez sur Lanceur d'applications > Zoom.
Apple Music
Diffusez plus de 100 millions de chansons et 30 000 listes de lecture sans publicité. Écoutez toute votre bibliothèque, découvrez de nouvelles musiques et écoutez les stations de radio en direct. Pour accéder à Apple Music, appuyez sur l'icône Apple Music dans le lanceur d'applications, scannez le code QR avec votre appareil mobile et connectez-vous avec votre identifiant Apple.
Remarque : un abonnement Premium Connectivity est requis pour diffuser Apple Music sur une connexion cellulaire.
Améliorations apportées à Apple Music
Avec cette mise à jour, Tesla a apporté des améliorations à Apple Music. Lors de la lecture d'une liste de lecture ou d'un album, Apple Music affichera désormais les chansons à venir dans la section « Suivant » comme les autres services de musique.
Tesla semble également avoir apporté diverses améliorations pour améliorer la lecture et la vitesse lors de la diffusion d'Apple Music. Les utilisateurs signalent une expérience plus fluide et plus rapide lors de la diffusion de musique en continu.
Écran de bienvenue
Les nouveaux modèles S et modèles X afficheront désormais une visualisation du véhicule sur l'écran central. Comme pour le modèle 3 et le modèle Y, cela donne aux propriétaires un accès facile pour ouvrir le frunk et le coffre, ainsi que pour verrouiller ou déverrouiller le véhicule.
Cela empêche les propriétaires d'avoir à se rendre à Controls chaque fois qu'ils ont besoin d'ouvrir le frunk/trunk de l'intérieur du véhicule.
La visualisation disparaît une fois que vous appuyez sur n'importe quelle autre zone de l'écran.
Publié : 05 mars 2023 14:16
par jjde34
Tout ce qui nous concerne déjà présent sur les dernières maj
Publié : 05 mars 2023 14:24
par k6_TV
rien de bien transcendant... attendons la prochaine :langue: :marrant:
Publié : 08 mars 2023 08:37
par GaPhi
Publié : 08 mars 2023 15:14
par jjde34
2023 6 1 installée, seule différence avec 2023 2 12 ajout de l'islandais
Publié : 08 mars 2023 16:59
par Franch77
Je n’ai aucune mise à jour 2023.6.1 ?
Publié : 08 mars 2023 17:17
par leonkennedy
@Franch77
Ça va arriver :clin:
Il n’y a pas de règle d’attribution ou du moins elle nous échappe et elle est proposée par vague.
A titre personnel, j’ai constaté que mes updates me sont toujours proposés le jeudi soir aux alentours de 22H - 22H30
Publié : 08 mars 2023 20:03
par LMD
@Franch77
La voiture a du détecter que tu ne parlais pas islandais :marrant:
Publié : 08 mars 2023 21:12
par Franch77
:marrant: :marrant: :marrant: :langue:
Publié : 09 mars 2023 19:50
par viper
: Mouhah: : Mouhah: : Mouhah:
Publié : 10 mars 2023 11:11
par BlackPanther
quelqu'un d'autre a eu la mise à jour Eyjafjallajökull ?
Publié : 15 mars 2023 20:15
par Daouda33
On en est où de cette mise à jour?
Même si elle ne sert à rien :marrant:
Publié : 16 mars 2023 05:41
par BlackPanther
Pas vraiment déployée pour le moment.
Le Manuel d’utilisation est pourtant en cette version.
Publié : 18 mars 2023 19:48
par GaPhi
Publié : 18 mars 2023 20:18
par jjde34
2023 6 8 en cours également, rien de nouveau selon la release note, à suivre.....
Publié : 19 mars 2023 15:47
par leonkennedy
@GaPhi
A la vue de tes posts, tu sembles avoir les MAJ assez tôt!
Ça donne quoi? :interroge:
Publié : 19 mars 2023 15:51
par leonkennedy
La version 2022.44.11 (pour les FSD Beta) semble enfin intégrer le Park Assist via le Tesla Vision
